Headlight problem
The front corner headlight on the driver side keeps popping out from the bottom. The mount just under the hood is screwed on light, but I can't figure out why the bottom won't stay locked in. Anyone know how to lock the bottom in?
On each hedlamp there are two adjustment bolts at the top and a nut at the bottom of the headlamp. On the headlight brakcet there is also a nut at the bottom of the bracket. I suspect you are missing a nut at the bottom.
