blower motor bolt size
ahardb0dy
Never mind, found out one of the bolts was the correct one, one the insert the bolt screws into was gone so just a hole in the plastic, the third hole had a broken bolt in it.
I installed a nut sert in the empty hole for a 1/4 - 20 bolt, the one that had the broken bolt in it I drilled it out until the insert pushed out and installed a second nut sert in that hole than re-installed the blower motor with 3 bolts, all good now.
