Automatic to Manual swap
Mkeesucker
Anyone done this swap? I really want mine to be a 5 speed. I have seen someone on youtube say that they have done the swap but i can not find anything about it on any forums. Any direction would be great. Thanks
I followed the Haynes manual to be honest, all the bolt holes are there including clutch pedal, lines, etc makes it really yes, but there is a couple tricks, like when you remove the trans you'll notice a bunch of wires and a switch that's controlled with a cable via your shifter, stick it in N or P (someone confirm this for me I'm not to sure since I did it the hard way) then take it off and lock it into position, I cut all the wires and then it was a nightmare to figure out the no start issue after wards. Otherwise if you have a donor and a week or two, also a homie or two doesn't hurt, should be no issue.
