theexbrit Posted May 2, 2014 Share Posted May 2, 2014 I searched but couldn't find a definitive answer, the question is..... Can you use a front strut spacer with the Krypton Fabs sfd? Link to comment Share on other sites More sharing options...
Precise1 Posted May 2, 2014 Share Posted May 2, 2014 It isn't in this? http://www.nissanpathfinders.net/forum/topic/23821-subframe-drop-for-r50/ I could have sworn I read something on that in the last month or two and the answer was yes, but I'm not sure where/who it was so I can't 'prove' it. B 1 Link to comment Share on other sites More sharing options...
theexbrit Posted May 2, 2014 Author Share Posted May 2, 2014 Ok, ok, so I didn't search very hard, but I did search! :laugh: Thanks for that link B. Link to comment Share on other sites More sharing options...
Precise1 Posted May 6, 2014 Share Posted May 6, 2014 No problem! Did you find the answer in there or do I have to do some digging? B 1 Link to comment Share on other sites More sharing options...
theexbrit Posted May 6, 2014 Author Share Posted May 6, 2014 :laugh: No, we're good. The answer appears to be that you could add another 1" or so by using a spacer. The angles etc, should be the same as before the sfd, just the body will be 4" higher so you could add the same amount of spacer lift as you could when it was stock. Link to comment Share on other sites More sharing options...
Precise1 Posted May 6, 2014 Share Posted May 6, 2014 Ok, good! I thought that was the answer, but wasn't confident enough to state it as fact. B Link to comment Share on other sites More sharing options...
