Guest kev7706 Posted February 2, 2005 Share Posted February 2, 2005 I have found this forum in my search for Pathfinder enthusiasts who may be able to help me with a problem. I hear a high-pitched noise that seems to come from the engine bay area whenever the brake pedal is pressed. It sounds similar to the noise an alarm would make, except it does not beep, it is constant. When the brakes are let off, the noise lowers to a certain level and slowly fades away. I just got a a flat tire fixed at a local shop and this occured just after leaving the shop. Also, 2 days before the noise occured, I went off-roading and got stuck in some mud on the right side of the vehicle. What could be the cause of this noise? Could it be related to either the tire repair or the off-roading? Thanks in advance. Link to comment Share on other sites More sharing options...
Trialsin26 Posted February 2, 2005 Share Posted February 2, 2005 Check your brakes. They may need to be replaced or cleaned. Any other suggestions out there? Link to comment Share on other sites More sharing options...
96pfinderSE Posted February 2, 2005 Share Posted February 2, 2005 I say clean your brakes. Might have some mud in there somewhere. I have had the same problem with other trucks. (brake parts cleaner helps) Link to comment Share on other sites More sharing options...
RowOSU Posted February 2, 2005 Share Posted February 2, 2005 Brake cleaning is definately in order. Out wheelin' one night buddy of mine got his blazer stuck beyond my rescue abilities (maybe if I had an automatic that would've been one thing, but I wasnt about to burn off ANOTHER clutch off road) so we left it for the night, after we got him out his brakes would make awful noises when applied, we took them apart, cleaned everything out and the noise stopped. So just try taking them apart, cleaning everything really well, maybe replace the pads while you're at it and you should be set to go -happy trails to you - cameron Link to comment Share on other sites More sharing options...
Guest kev7706 Posted February 2, 2005 Share Posted February 2, 2005 Thanks for the responses, guys. I will definitely check and clean my brakes or replace them if necessary. Link to comment Share on other sites More sharing options...
