1993 Pathfinder Inner wheel bearing grease seal.
MrEviLDeD
Before I start digging around. Is there any special thing I need to do to remove the grease seal to get access to the inner wheel bearing? Is it just rubber and pushed into place, do I need to turn it? I do not want to ruin it. I have to reuse it no other option..
Also good note to self, take the whole hub assembly apart while the rotor is still on the truck :) Or at least make sure you have a bench vice.
