Fuel/Temp Gauges
DanCamm
Did the search and read about the voltage regulator replacement. Question is, does this fix also apply on 88's? The "Common Problems" thread said '91 and up.
Just want to make sure before I tear the cluster out.
Thanks
If you can receive a pdf file, I can send you a little write up I did on this fix. It's 406kb in size. If your gauges look like the one in the writeup (same layout) it should work for you. Just PM me and I'll e-mail it to you.
Denis
I'll look it up tomorrow, I'm heading on out to an electronics parts supplier store in the morning before work. If they're real cheap and easy to get ahold of, I'll buy a bunch of them and sell 'em back to anyone that needs one as a complete stock replacement, soldered with the same color wires and terminals and everything. I'm not out to make profits here, just to help people.
