Replaced rear links but still have issues
blk01acr
Had the usual wobbling issue at highway speeds and replace all four rear link assemblies. She tracks down the highway nice and straight now but when I tip into the accelerator it darts left and when I let off it darts right. This is most pronounced at highway speeds. Is this a track bar/panhard bar issue or have I missed something else.
Thanks in advance for the help
You replaced all four links? If so, check your bolts. Make sure good n tight. Also check your sway bar bushings and links. Those could be toast. Yes, do check your panhard bar bushings. That does keep the rear centered in the back. So if the bushing are non existent. then yes, you can definitely have a sway.
Thanks for the quick response. I replaced all four links with Dorman units. With the way it changes direction by applying or removing torque, I suspected that it may of had something to do with the panhard bar. I will have another look at the sway bar link bushings.
Thanks again
Jim
