MrEviLDeD Posted February 4, 2014 Share Posted February 4, 2014 My 93 Pathfinder has rusted out and I need a replacement. Unfortunately there are not any 93's. I have however found a 96 that has a problem with first gear. It is a manual and I just wondered if I could swap out the transmission from the 93 and use it in the 96? The 96 is a great deal other than the transmission problem. Thoughts? Link to comment Share on other sites More sharing options...
MY1PATH Posted February 4, 2014 Share Posted February 4, 2014 you can but the 87-95? MT has different gear ratios in favor of wheeling. (.852 5th off the top of my head) The R50 you're looking at will turn a lower RPM on the highway with its stock tranny(.811 5th off the top of my head) and a higher RPM on the freway if you put the 93 transmission (.852) in it. Other thoughts, canibalize the two? use the .811 5th gear from the 96 in the 93 tranny to make a wheeler tranny that curises well? Link to comment Share on other sites More sharing options...
