88 autotragic
vagabond
Been out in the desert this last week playing with the 88, I noticed the tranny was shifting like it had a shift kit in it 3 days ago it shifted like that for 2 days, now it's back to shifting it's nice smooth shift.
The fluid is nice and red no burnt smell and the fluid temp hasn't gotten over 210, normally running about 140/150.
Any ideas????????????
running an inline filter,no on the rad cooler 2 external coolers 1 is the ford exploader tranny cooler, trans was serviced late last year,
Trans was rebuilt about 2 years ago and has been working with no probs, everything seems normal now.
Don't condemn the transmission so quickly. Yes, change the filter, it should take a minute. Can't hurt anything. However the hard shifting you had is not always the transmission. A bad TPS sensor can make the transmission shift hard. If you have hard shifting again in the future, give that a look. The specs for it are in the FSM.
You can check the tranny brain for stored codes as well, but unless there is a light pattern at start up, there shouldn't be any, kind of like the CEL. Disecting the old inline filter sounds like a good plan; always try to learn...
