marbiol Posted October 10, 2013 Share Posted October 10, 2013 Hi All, I need to replace my headlights due to some chipping in the glass ( apparently this is a fail for a driver's test that I need to take to get my US license). I've seen the range of aftermarket headlight units, but they all seem to have plastic lenses. Are there any that have glass lenses (ideally with DOT markings for the inspector), or would I need to go full OEM? If OEM, where would be the cheapest place to get them? Cheers, Dan. Link to comment Share on other sites More sharing options...
adamzan Posted October 10, 2013 Share Posted October 10, 2013 Rockauto has glass replacement ones. I have a tyc brand one on mine and it is glass. Looks just like stock. Link to comment Share on other sites More sharing options...
marbiol Posted October 10, 2013 Author Share Posted October 10, 2013 How was the sealing on the TYC ones? I read a study that seemed to show that the beam patterns weren't compliant with FMVSS 108 and the moisture sealing was lower quality than the OEM ones. The main issue is that I don't want to get to the test center and get turned away for non-compliant lights. http://www.capacertified.org/press/CAPALighting3.pdf Link to comment Share on other sites More sharing options...
adamzan Posted October 10, 2013 Share Posted October 10, 2013 (edited) It seems fine, it's been on my truck since I've owned it, and the previous owner was a member here. It has been on there at least 5 + years. The cheapest route, of course is to get a used one somewhere. Edited October 10, 2013 by adamzan Link to comment Share on other sites More sharing options...
Bubbley11 Posted October 10, 2013 Share Posted October 10, 2013 I got a one from a pick and pull for 21 bucks. It would have been like 15, if I hadnt had to grab the base then the lens. If you find a whole light with base and lens intact,it should be real cheap. Link to comment Share on other sites More sharing options...
