Lubrication of driveshafts
hagge
Hi!
I am thinking about servicing the drive shafts on my 1994 3.0 v6 Terrano/Pathfinder.
Anyone that knows how many lubrication point there are on the rear and front drive shafts?
I can only find one...
And can i get to the fittings with a normal grease gun? it looks tight in the u joint.
Some u-joints on the rear driveshaft have bolts that can be removed so you can grease them. It's awfully tight for a grease zerk, but you can still get the grease in there. That's what I do. As stated, the front shaft should have a zerk for the slip shaft.
