Fixed my rear defrost
RF600
The rear defrost on my rig has not worked since I bought it. Today I dove into it. I checked this and that. Pulled relays, checked the grid, ran a different power wire. Still nothing.
After all that, it was narrowed down to one side of the wires connecting to the grid. What it ended up being was just a ground that had corroded. I cut a little bit of wire off that was bad. Put a new eyelet on. The screw holding the ground on didn't tighted up properly, so I put a new screw in. It now works.
The ground is on the passengers side. Where the ground mounted was painted. The only connection was the hole. I scraped the paint off around where the eyelet would sit. It should last for quite a while now.
