johnyreb Posted August 18, 2013 Share Posted August 18, 2013 I'm trying to wire in the aftermarket deck i got into my 92 se and have a small issue i can't figure out where to run the ground wire for the radio i checked the crutchfield table and it seems like it will be very helpful other than not tellin wich wire is the ground anyone know? Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 18, 2013 Share Posted August 18, 2013 There is not a ground wire in the factory harness !! Just hook the ground wire to the metal bracket that is under where the radio mounts, either use an existing screw or install a new one. 1 Link to comment Share on other sites More sharing options...
johnyreb Posted August 18, 2013 Author Share Posted August 18, 2013 Ok simple enough thanks Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 18, 2013 Share Posted August 18, 2013 Welcome Link to comment Share on other sites More sharing options...
93_ditchfindah Posted March 5, 2014 Share Posted March 5, 2014 sorry for such a late reply! but your radio will actually ground from the antenna input. when you plug in your radio intenna it actually ground the whole radio but i assume you already fixed your problem! hope you got it working! Link to comment Share on other sites More sharing options...
