'91 SE Pathfinder
  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
Yep! Same color... I kinda like the neutral earth tone. A split boot replaces the whole boot without removing the axle. Always carried one or two when I was racing VWs, just didn't know if they were available for the Pathys....
  • 3 weeks later...
Been trying to figure out this "noise" since the lift. During slow turns with changes in elevation I feel and hear a thump, thump, thump, but no slipping per say. Only seems to do it at extremely slow speeds and on bumps. My first thought was the LSD, then I thought maybe wheel bearings, then I thought maybe the new Rancho shocks topping out... I am gonna take some laser temp readings on the end of the axles tomorrow after driving to work to look for excessive heat in either axle looking toward bearing issues. Any thoughts? Rebuilding the clutch pack looks like a PITA, thinking maybe I should go with a standard rear end and a locker, only because all the tolerances in rebuilding the LSD looks insane.
