86.5 TPS voltage issue
I have a problem involving code 42 TPS. The input voltage is supposed to be variable from 0.5 to 4.0 volts and its supposed to change when the accelerator is depressed, but when I measure it I only measure 0.03 volts and it doesn't change. I've tried using a different ecu and the same thing is occurring. I've also checked continuity on all the wiring to the tps and everything is fine. Any ideas?
Kinda weird, is yours a 5-speed or automatic? There's two things built into one TPS, an idle/full throttle switch and a potentiometer for the automatics.
it might be worth mentioning that while I was originally trying to adjust it I was measuring voltage fine and it started out of nowhere not reading healthy voltage, millivolts, almost none...
