Power Seat Memory
The memory on my power seats does not work, it had not worked in over a year but i never cared because its my truck and only I drive it, until now, my girlfriend jsut got her license and she is 5'3 and I am 6'0 so she keeps moving the seat all close to the point where I can not even get in, so I thought it would be nice if I could program the 2 memories on the seat, it is a 2002 PF LE and it has 3 buttons, I read the manual on how to program them but it seems there is no power going to it, does anyone know if this could jsut be a fuse or is it a wiring problem? if it is a fuse do you know which one? any inofrmation or help is greatly appreciated, thank you
Check if the Dashboard ADP (auto driver postion) switch is activated. Should be below dimmer switch. Make sure it is not on cancel. If ADP lights up when buttons pressed then that is a good sign.
When programming, press button for at least two seconds when assigning seat postions to either 1 or 2. When assigned, press for button for at least 2 seconds to select seat postion.
hope that helps!
Let me know.
