SFD steering HELP!
DsR50
ok so i have finished the SFD with 3 inch blocks and 5 inch strut spacer. I really need help with my steering linkage. Yea i could pay the 165$ for the linkage or make my own. so i went to the pick n pull and got one of those ujoints so now i have 2 total and got somthing hooked up but it binds so any ideas?
Back in the day...wow, that got me.
I think I used the linkage (below the steering column) off a 91 Accord from a local JY.
Should look something like this when all is said and done (the primary reason for using this was the same shaft diameter/spline count IIRC).
One thing I'd keep in mind is that you've moved the steering rack away from it's preferred position (basically in-line), so you may want/need to consider rotating the rack to help with the binding issue.
Hope that helps.
Edited by Rick13
here is the steering linkage i made, works good with no binding. I didnt know that you could rotate the rack, i think ill cut the linkage down to compensate for the adjustment
<a href="http://s1073.beta.photobucket.com/user/donovan_91/media/2E3128E3-C47B-4DAD-884C-AE8C1B99E1F5-2001-000002FA307231BB_zpsecfc7211.jpg.html" target="_blank"><img src="http://i1073.photobucket.com/albums/w387/donovan_91/2E3128E3-C47B-4DAD-884C-AE8C1B99E1F5-2001-000002FA307231BB_zpsecfc7211.jpg" border="0" alt=" photo 2E3128E3-C47B-4DAD-884C-AE8C1B99E1F5-2001-000002FA307231BB_zpsecfc7211.jpg"/></a>
