Stinka Posted December 5, 2012 Share Posted December 5, 2012 What's the stock length ? Need some longer ones as Ive got some serious shimming to do after 3" lift I reckon I have to add 10mm as there some serious negative and my steering is light as hell Also, what is the hardness/strength spec of the bolts Cheers Link to comment Share on other sites More sharing options...
Stinka Posted December 5, 2012 Author Share Posted December 5, 2012 This is the kind of neg camber I have on both wheels, is very visible Link to comment Share on other sites More sharing options...
Stinka Posted December 5, 2012 Author Share Posted December 5, 2012 Also steering is very light now Link to comment Share on other sites More sharing options...
Precise1 Posted December 5, 2012 Share Posted December 5, 2012 Here is some info... If I do remember, they're 14x1.5x50mm 8.8's. I got some 14x1.5x70, 8.8's from a tractor supply store for about $5 apiece a while ago and they took care of the positive camber with plenty of threads to spare. I believe I am correct. Stock is 50mm length, and it is a 14mm x 1.5 thread pitch. I got some 14x1.5 in a 60mm length @ a local bolt specialty shop (TACOMA SCREW, has every fastener the hardware store doesn't) I got these because my Alignment shop said they would feel more comfortable getting my lifted vehicle to spec if they had a few more threads in the frame. And here (they do have others too)... http://www.boltdepot.com/Metric_hex_bolts_Zinc_plated_class_8.8_steel_14mm_x_1.5mm.aspx B 1 Link to comment Share on other sites More sharing options...
Stinka Posted December 5, 2012 Author Share Posted December 5, 2012 Awesome, thanks Link to comment Share on other sites More sharing options...
