Uca to frame bolts
Stinka
What's the stock length ? Need some longer ones as Ive got some serious shimming to do after 3" lift
I reckon I have to add 10mm as there some serious negative and my steering is light as hell
Also, what is the hardness/strength spec of the bolts
Cheers
Here is some info...
If I do remember, they're 14x1.5x50mm 8.8's. I got some 14x1.5x70, 8.8's from a tractor supply store for about $5 apiece a while ago and they took care of the positive camber with plenty of threads to spare.
I believe I am correct. Stock is 50mm length, and it is a 14mm x 1.5 thread pitch.
I got some 14x1.5 in a 60mm length @ a local bolt specialty shop (TACOMA SCREW, has every fastener the hardware store doesn't) I got these because my Alignment shop said they would feel more comfortable getting my lifted vehicle to spec if they had a few more threads in the frame.
And here (they do have others too)...
http://www.boltdepot.com/Metric_hex_bolts_Zinc_plated_class_8.8_steel_14mm_x_1.5mm.aspx
