WxChaser Posted December 5, 2012 Share Posted December 5, 2012 Hey all, Quick question, would a dashboard (just the guages) from a 90 pathfinder fit into a 93 Pathfinder? They both look similar in size, but the layout is just a little different (I like the 90 better than the 93, don't ask me why). Looking to get it from a fellow member on here. Thanks! Link to comment Share on other sites More sharing options...
Kyle94 Posted December 5, 2012 Share Posted December 5, 2012 the problem isnt the fitting.. its the plugs if i remember correctly. i tried to put a 92 (same from 90-92) dash in my truck. the plugs or something were different. im not really sure tho. so look at it/pics and be sure. i ended up not using the one i had... Link to comment Share on other sites More sharing options...
Tungsten Posted December 5, 2012 Share Posted December 5, 2012 (edited) Yes it will physically fit into the hole but you will need to do some slight re-wiring and I think the voltage regulator is inside the ECU on the newer one instead of the top of the cluster. Going from a newer to an older should be easier than going from an older to a newer. Edited December 5, 2012 by Tungsten Link to comment Share on other sites More sharing options...
