Noob here.don't own a PF yet....
rollingrock
Yep, it looks like the torsion bars have sagged a bit. Not too bad though, I have seen far worse. Depending on the adjustment left, you might be able to just crank it back up, or check out the 'Re-indexing your torsion bars thread' in the Garage/How To section.
Guys, I have never heard of this tire size...it has Michelin LTX M/S 30X9.5 R15 tires. What in the hell is this size?
Please tell me this isn't b/c of these wheels...jus wondering if I can get a "normal" sized tire. Sure hope I am not showing my ignorance here but I thought I knew tires.
The 30x9.5 is a moderately common size, and the smallest of the 'high flotation' tires geared towards offroad and airing down. They are always called out by their diameter X tread width.
235/75/15 is the 'metric' version of tire sizing, 235 being the width in mm (25.4 per inch)/75 being the percentage of width that is the sidewall height/15 is the rim diameter in inches.
yes, I am used to seeing 235/75/15 type sizing. Ok, so help me here for a sec. The stock size according to Discount Tire is 30/1050-15 ....is that a smaller tire than what I hve on there or bigger?
I cannot tell. These seem to "stick out" just outside of the fender flares. I need 1 new tire.
As Trogdor said, you have an inbetween size for now (235/75/15 are generally 29x9" tires). It should say 31x10.5" on the door plate, but they don't seem to stick out much at all. Honestly, for now I'd just try to find a used spare. What type of tire are they? If they aren't at least A/T tires they might not be good enough for your hunting trips.
Oh, congrats BTW, I'm glad you got what you wanted! It looks pretty clean. :aok:
Now, go check out the 'Transmission cooler' threads...
