96Pathfinder4x4 Posted November 11, 2012 Share Posted November 11, 2012 When it rains it pours. Finally got around to pulling the Pathy into the garage to tackle the SFD from Krypton Fabs. While helping my buddy replace his ebrake cable on his Bronco, I look in the garage and see a drip under the Pathy. Thought it might be water drops....not that lucky. As we work on the Bronco, I see the puddle get bigger. I crawl under and see that it's coming from the bell housing. Rear main seal, I'm guessing. From the manual, it looks like I have to remove alot just to lower the trans and get to it...so I'll be tackling that today. Maybe the SFD will put itself on when I'm not looking. Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted November 11, 2012 Author Share Posted November 11, 2012 (edited) From the manual: Remove/disconnect: -Crankshaft position sensor (top of trans) -Front and rear exhaust tubes -Fluid charging pipe -oil cooler pipe -Propeller shaft (mark flanges, remove & plug rear of trans <- Going to replace this seal, while I'm in there) -Speedo cable -AT control cable -AT harness connectors -starter -Gusset and rear plate cover (secures engine to trans) -Bolts at torque converter (by turning crankshaft) FINALLY - Support trans and remove rear mount bracket and bolts securing AT to engine Edited November 11, 2012 by 96Pathfinder4x4 Link to comment Share on other sites More sharing options...
devonianwalk Posted November 11, 2012 Share Posted November 11, 2012 (edited) Geeeezzzz.... Edited November 11, 2012 by devonianwalk Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted January 1, 2013 Author Share Posted January 1, 2013 So to update: After talking to a couple of people that have had success in this area, I bought a bottle from Autozone. Don't remember the brand. It was one of the less expensive ones....about $10. I poured it in and in about 20/30 miles it stopped leaking!!! Link to comment Share on other sites More sharing options...
Towncivilian Posted January 1, 2013 Share Posted January 1, 2013 Bottle of what? Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted January 2, 2013 Author Share Posted January 2, 2013 I think this is what I used. Bar's Main Seal Repair. http://www.autozone.com/autozone/accessories/Bar-s-Rear-main-seal-repair/_/N-260b?itemIdentifier=426114_0_0_ Link to comment Share on other sites More sharing options...
Towncivilian Posted January 2, 2013 Share Posted January 2, 2013 I like how AutoGroan's site says "Radiator Cooling System" for the "Automotive System Application". Was it some thick stuff? Well, at least you didn't throw some Lucas snot in there. If the leak stays stopped after an oil change or two, even better! Link to comment Share on other sites More sharing options...
96Pathfinder4x4 Posted January 2, 2013 Author Share Posted January 2, 2013 It wasn't that thick...I remember because I was actually a bit surprised when I poured it in. I sure hope so. If it does leak again, I'll give 'er another $8 gamble. Link to comment Share on other sites More sharing options...
