Kenmo77 Posted September 12, 2012 Share Posted September 12, 2012 I recently replaced my rack and pinion along with outer tie rod ends on my 97 Pathfinder. All was fine for about a week. Today I heard a weird noise when I was in a turn, then again with a snapping sound coming from behind the steering wheel. Since then my airbag light has been flashing... I pulled the fuse just to make sure I didn't get a deployment but I don't know where to go from there to fix whatever I messed up!! Any suggestions would be greatly appreciated!! Thanks in advance. Link to comment Share on other sites More sharing options...
Towncivilian Posted September 12, 2012 Share Posted September 12, 2012 That would be your clock spring (aka spiral cable) that snapped. Does your horn work? How about cruise control? Link to comment Share on other sites More sharing options...
Kenmo77 Posted September 13, 2012 Author Share Posted September 13, 2012 I don't have cruise and I haven't tried the horn. I will tomorrow for sure. If that is the problem how hard is it going to be to repair? Link to comment Share on other sites More sharing options...
Towncivilian Posted September 13, 2012 Share Posted September 13, 2012 Page RS-9 of the factory service manual has instructions on removal and replacement. 1 Link to comment Share on other sites More sharing options...
Kenmo77 Posted September 14, 2012 Author Share Posted September 14, 2012 I did check the horn today and indeed it does not work. Thank you for your help! I will order the part and follow the instructions for removal and replacement. Greatly appreciated! Link to comment Share on other sites More sharing options...
Towncivilian Posted September 14, 2012 Share Posted September 14, 2012 Good luck! Link to comment Share on other sites More sharing options...
Alkorahil Posted September 14, 2012 Share Posted September 14, 2012 (edited) Yep.........steering angle sensor (aka clock spring) not a cheap part either... should be part number: 25554-0P025 I can get if for you for $433.40 (nissan list: $481.56) I see you are in Roanoke, I am in McKinney. If you want to give me a call tomorrow I can check your VIN and see what part it does use and see what I can do for you. Edited September 14, 2012 by Alkorahil Link to comment Share on other sites More sharing options...
