Diesel woes: TD27 Boost leak
Stinka
Its a 2002 TD27 turbo intercooler with bosch manament, diagnosed with consult 2
So it goes into limp mode only after its warmed up giving a fault about turbo pressure
It resets limp mode when you turn ignition off and on again ok for 30 secs, then power loss again, rinse and repeat. But its fine for the 10 or so miles its takes from cold to reach max working temperature, so its only when warm.
This makes me think the boost loss is happening when something metalic is expanding and opening up a crack.
I'n my attempts to sort this problem so far I've had intercooler tested and its fine, replaced inlet manifold gasket, resealed throttle body, removed flap spindle from throttle body and filled holes with chemical metal. Remove EGR valve completely and plated the inlet and exhaust holes with a 4mm tick blanks that i bolted and sealed with copper rtv.
What else could be causing boost loss after reaching full temp ?
is it really losing boost ??? I mean, could it be the boost sensor that has gone south ? I don't know exactly how it works, but if there is a signal going to the computer saying the boost is low and putting it in limp mode, then there a sensor voltage somewhere you should be able to look at...
just my 2 cents..
good luck.
Sorted it.
Basically the TD27ETI engine uses the MAF sensor to work out boost pressure. I had a cheap chinese copy MAF off ebay in the motor, just put my old knackered bosch one in, it still runs poor like it did before the chinky MAF but its stopped going into limp mode.
Those pesky chinks have a lot to answer for :/
