Speedo Swap
I have recently installed the factory gauge cluster from a Canadian spec Pathy. The speedometer area of the cluster reads in Kilometers rather rather than MPH. Does anyone know if the 'gear set' which is what operates the odometer and trip meters are actually geared differently from the models shipped to the USA, or did Nissan just use different face plates on the 'speedo's' that are showing Kilometers per hour as the primary indicated speed?
What I've done, is swapped from a 'US' cluster to a Canadian cluster . What i'm considering doing is just replacing the 'face plates' from the broken USA speedo to the operational Canadian speedo.
Thanks in advance for any comments or suggestions.
Don't replace the face plates. You can replace the entire section but once you take the needle off it's really hard to put it back on into the right spot. There is no different gear set between KMH and MPH clusters.
