Factory fog lights
jerryb
My 2004 didnt come with factory fog lights and I would like to install them. I think it makes for a better look.
Can anyone tell me if all the factory harnesses have the plugs for the fog lights? I guess the second question would be....If so, I need the fog light steering column switch......is this a straight plug in as well if I scrounge one up at the scrap yard?
Thx
No promised but all the nissans I have and have worked on have all had the wiring there. You could look by your switch and see if there are any extra plugs or pins. If so then its a safe bet they are there on the other side as well.
Remove the front plastic blank that fills the gap where the factory lamps would go. Behind that plastic blank you should be able to reach your hand in there and search for an empty wiring harness. I've read somewhere on these boards where someone attempted what you are trying to do with their R50. I can't remember if they were successful or not but, I do recall that they did have the wiring harness already in place.
Thanks.... I will begin searching the scrap yards and kijiji. If it works I will post the details.
I also found an ebay kit with oem like lites and a push switch that looks like it could fit into the seat heater cutouts....... A Last Resort.
Sent from my Transformer TF101 using Tapatalk 2
Edited by jerryb
Found the correct steering column switch at the Boneyard today...... For a buck.! I know. I know..... Should have checked if the fog lights connectors are there first but what the heck...... A buck! The guy must have got lucky last Night!
No fog lites....... Yet.
