TShep704 Posted June 7, 2012 Share Posted June 7, 2012 I'm stuck, got no way out, my muffler is under water and its about door level... Am I screwed if I turn the engine off? Someone please call or text 941 527-5181 Link to comment Share on other sites More sharing options...
muddfildvaynes Posted June 7, 2012 Share Posted June 7, 2012 It won't hurt anything, the water will get thrown out with cranking the engine, worry more about getting it into your intake.... 1 Link to comment Share on other sites More sharing options...
dududuckling Posted June 7, 2012 Share Posted June 7, 2012 (edited) As long as your intake is not under water, I think you're good. I was in the same situation, muffler under water, water coming in passenger side, and I turned the engine off. I turned it on no problem. Boat engine starts underwater afterall? Edited June 7, 2012 by dududuckling Link to comment Share on other sites More sharing options...
TShep704 Posted June 8, 2012 Author Share Posted June 8, 2012 thanks guys. my phone died when i posted this so i just left it running just to be sure... ended up tearing the whole front end off and tore both tie rob boots off... Link to comment Share on other sites More sharing options...
Towncivilian Posted June 8, 2012 Share Posted June 8, 2012 (edited) Be sure to change the diff and transfer fluids and regrease both driveshafts and maybe the front wheel bearings. Water entry is bad for lubricants. If you off-road often, cheaper conventional fluids changed at shorter intervals will save money over synthetic lubes. Edited June 8, 2012 by Towncivilian Link to comment Share on other sites More sharing options...
jerryb Posted June 12, 2012 Share Posted June 12, 2012 LOL...where are the pics? 1 Link to comment Share on other sites More sharing options...
