paoldschool Posted May 29, 2012 Share Posted May 29, 2012 I have a coolant leak where the line connects to the upper plenum by the egr valve. This line runs over to the throtle body and then back. My question is why does coolant run through there, and could the lines that run to the back of the upper plenum just be looped to do away with this??? Link to comment Share on other sites More sharing options...
pathfounder Posted May 29, 2012 Share Posted May 29, 2012 Coolant is run to the throttle body to prevent "carb" icing. You want it. Link to comment Share on other sites More sharing options...
paoldschool Posted May 30, 2012 Author Share Posted May 30, 2012 I was able to thread the hole with a 1/4" pipe tap. I put a street "L" in it and a 1/2" hose barb and hooked everything back up, and so far so good... Link to comment Share on other sites More sharing options...
albino Posted June 4, 2012 Share Posted June 4, 2012 I think I have the same leak as you, looks like I already have an "L" as the connector and coolant is leaking from where the "L" connects to the block... did you have to drain the whole system to fix this or were you able to disconnect the hose with little coolant coming out? Link to comment Share on other sites More sharing options...
pathfounder Posted June 4, 2012 Share Posted June 4, 2012 You'd probably want to drain a bit out of the rad just to save having a mess, but no, you wouldn't need to drain the whole system. Link to comment Share on other sites More sharing options...
paoldschool Posted June 8, 2012 Author Share Posted June 8, 2012 Mine had leaked down a bit, so I didn't have to drain anything. My was damaged while putting the upper plenum back on after replacing the valve cover gaskets and the timing belt and cam seals. So it wasn't all the way full, the leak was found on the first start up. After the leak was fixed it took about 1/2 gallon to fill the system. I used black permatex on the fittings and also where the hose went over the fitting. So far so good, no leaks. Next project is to rebush the rear trailing arms, and new rear shocks... Link to comment Share on other sites More sharing options...
