Fuel Leak from Rear
95Finder
Whats up, I have a fuel leak and was wondering if anyone has had similar symptoms and what the fix is for it. I had noticed that the car smelled like gas. The gas seems like it might be leaking from the line that goes from the fill hole to the tank. The rear shock on the passenger side is completely covered with gas. Can I pull out the filler thing and inspect the line for cracks? If not then what is the best way to inspect the line? There is also a discolored line running right under the gas cap that runs down the outside of the body. I am thinking fuel is leaking down the inside of the fender wall and causing this. Any help would be appreciated. Thanks.
Thanks, I actually took the rear passenger side wheel off to try to see where it was leaking from. It is coming from one of the three fuel lines that are attached to the inside of the frame rail. Anyone know how much new fuel lines cost for the Pathfinder or what size diameter and what lengths of ss line I would need? Later
