smoke Posted April 22, 2012 Share Posted April 22, 2012 Does anyone know where I can pick up a factory service manuel for a old 83 hardbody pick up?? It has fuel system problems and I can not find all the curcuits and wires for it....the body and frame are hiding what Im trying to see and locate...... Thanx for your time Link to comment Share on other sites More sharing options...
ahardb0dy Posted April 22, 2012 Share Posted April 22, 2012 (edited) An 83 pickup would not be a hardbody, it would be a 720 series, you would need to check E-bay for a FSM. Here is one advertised as a FSM, for an 81, should be pretty much the same as an 83, but no pic of the actual manual: $20 http://www.ebay.com/...4c52414&vxp=mtr You can also go to Autozone.com, register for free and they have service manuals online that are close to the FSM. Edited April 22, 2012 by ahardb0dy Link to comment Share on other sites More sharing options...
Puckstoper9 Posted April 22, 2012 Share Posted April 22, 2012 There is a relay for the fuel pump that is located in the foot well on the passenger side. Also check out http://www.720world.com. There is a ton of information on there and a few guys that know the 720's inside and out. The fuel pump is not inside the tank it is on the outside of the frame rail in front of the passenger rear tire. If you still have the original carb you will have a fuel filter in the carb and one before the fuel pump. Link to comment Share on other sites More sharing options...
Precise1 Posted April 30, 2012 Share Posted April 30, 2012 All correct. I don't have a FSM, but I'm pretty sure I have a Chiltons or Hayes manual in the garage; thought I daw it when I moved and was surprised I still had it. Let me see if I can find it tomorrow and I can look up what I can or just send it to you. Again, let me try to find it, the garage is a mess. B Link to comment Share on other sites More sharing options...
Puckstoper9 Posted April 30, 2012 Share Posted April 30, 2012 The hayes manual for the 720 is the same one as for the wd21 pathfinder and hardbody's. Link to comment Share on other sites More sharing options...
