shermo Posted April 19, 2012 Share Posted April 19, 2012 IVE MACHINED A 2INCH BODYLIFT FROM SOLID ALUMINIUM , I KNOW THERE IS A FAIR FEW THINGS U HAVE TO MODIFY WHEN FITTING A 3 INCH LIFT AND I WAS WONDERING IF ANYONE HAS FITTED A 2 INCH LIFT THAT CAN TELL ME WHAT THE HAD TO MODIFY IF ANYTHING AT ALL . 1 Link to comment Share on other sites More sharing options...
pathybuilder Posted April 20, 2012 Share Posted April 20, 2012 The only thing I had to modify were the slots in the body where my ARB bumper brackets attaches to the factory mounts. You likely won't have this problem. I did separate all the lines from the passenger side firewall before the lift, some fit back to their original positions some needed modified routing. I also removed the loop style bracket that goes around the drive shaft, just behind the transfer case. That's all I can think off, I didn't have to modify the 4x4 shifter linkage as those with the 3" BL do. Link to comment Share on other sites More sharing options...
shermo Posted April 21, 2012 Author Share Posted April 21, 2012 (edited) thanks for that , did u have to do anything with the steering arm , if u can remember what bolts did u use ie size and pitch Edited April 21, 2012 by shermo Link to comment Share on other sites More sharing options...
pathybuilder Posted April 21, 2012 Share Posted April 21, 2012 It was a while back, but I remember removing the steering arm by loosening the pinch bolt and sliding it back off the steering box, then re-installing it once the lift was in, when re-installing it, you just have to stretch it out a little. As far a bolts go, I used whatever came in the kit from Automotive Customizers. You will have the use the same as whatever you remove as they thread into the factory body mounts. Link to comment Share on other sites More sharing options...
Nice186 Posted April 30, 2012 Share Posted April 30, 2012 How did u make the parts of the body lift? Like what is needed to lift it? I'm new to the "lift" part. I do have a CNC machine that I can use to make parts but I wouldn't have a clue on how to start building a part to "lift" my pathy. Do you still have the blueprint or file you used if you used a CNC machine? Would love to check that out if you still have it (null) Link to comment Share on other sites More sharing options...
