rear window wiper
Firehawk
Does the rear window have a washer fluid reservoir somewhere? I swear I can hear a motor run when I hit the button but if that's the case it's out of fluid b/c nothing comes out. Looked in the owners manual and could only find info on the one for the windshield.
Sorry if it's a silly question :|
Edited by Firehawk
Yes there are 2 different pumps. If nothing is coming out check that the line and nozzle isn't clogged. One quick way you can try to fix it is to remove the nozzle, hang that hose out of the hole, and hold down the wash switch until you see something come out.
Very cool. It must be clogged b/c the front work fine. I will check the line and blow air thru the same time I check the drain(s) for the sunroof.
Thanks guys!
