Rear shock compatibility Pathfinder/Hardbody
joshellis
Hi all. I'm looking at getting a Rough Country lift kit w/ UCAS & shocks for a D21 hardbody for $339. I figure I'll try to sell off the leaf shackles. My question is will the rear shocks for the HB bolt onto the Pathfinder? Or should I just look for a kit w/ just UCAs and (unfortunately) HB lift blocks.
try cross referencing part numbers on rock auto. if they match then your in luck for aftermarket as well.
the HB shocks run front and rear of axle and pathy shocks are straight above it. But at an angle. so its a 50/50 shot.
Edited by MY1PATH
Some people have had luck calling Rough Country (or maybe if your local 4x4 shop can order, might seem more legit that way...) and just getting the UCA's. Say you were in a front end accident, or something of the sort. Then you can get whatever brand shock you want, without being tied into the Hardbody package.
