forum topic display issue
Cuong Nguyen
Bottom of the screen where it sais filter options you can choose different lengths of time :aok:
Edit: I should add that it is not there when just using the new content button, but when just say browsing through the general section or 90-95 section. and if using the search there is a selection for date entrys you can use as well.
Edited by nunya
Git out of this thread so you are in the General section. Scroll down to the bottom of the page. Under the last thread listed is a dark blue bar that runs across the screen. In the middle it should say something like "Click here to set filter options". Click it and it will come up. I'm not sure if it is a global set or just for whatever section you are in but that should be easy to figure out. :aok:
