bonehead Posted December 21, 2011 Share Posted December 21, 2011 (edited) what is the symptoms of a bad EGR valve?? i have changed alot of sensor in my truck and spent way to much $$ my ecu shows 55 but my truck still runs like crap and when it's warmed up it will not start until it cools down after an hour or so. things i've changed........... -- fuel pump, feul filter, temp. sensor, TPS, MAF, knock sensor, cap & rotor, plugs & wires, water pump, timing belt, and thermostat. now i'm thinking EGR. Edited December 21, 2011 by bonehead Link to comment Share on other sites More sharing options...
Tungsten Posted December 21, 2011 Share Posted December 21, 2011 If you are suspecting the EGR valve, you can test it by pushing up on the diaphragm and see if it moves up and down. Link to comment Share on other sites More sharing options...
Precise1 Posted December 21, 2011 Share Posted December 21, 2011 Yes, exactly, IIRC at idle with it warm it should make the motor stumble a bit. For good troubleshooting info, go to the Garage section/pinned service manual info to download your own copy of the Factory Service Manual. It is invaluable for this type of information... B Link to comment Share on other sites More sharing options...
bonehead Posted December 21, 2011 Author Share Posted December 21, 2011 ok EGR works fine. i'm lost now dont know what to do at this point. Link to comment Share on other sites More sharing options...
sewebster Posted December 21, 2011 Share Posted December 21, 2011 Vacuum leak? Check the timing itself? Injectors? But yeah, look in the FSM... they have troubleshooting procedures for all kind of symptoms. Link to comment Share on other sites More sharing options...
bonehead Posted December 22, 2011 Author Share Posted December 22, 2011 what bout the throttlebody its self? Link to comment Share on other sites More sharing options...
Tungsten Posted December 22, 2011 Share Posted December 22, 2011 A vacuum leak or bad MAF sensor wiring will make it run like garbage. Link to comment Share on other sites More sharing options...
