Measurements from a rear tire carrier?
Earth1
If anyone feels so inclined, bored or otherwise helpful,
I'm thinking about using a Pathy tire carrier on another project. I need to find the measurements of:
1. hinge to hinge; bottom of top mount -to- top of bottom mount (where the tail lights are)
2. bottom of upper tube to the highest point of the latch plate
3. tube diameter
4. body corner (hinge side) to each mounting bolt on the strike plate
thanks in advance!
Thanks...
I'm looking at both. I think the r5o looks newer and I like that it maybe latches lower, but the mounts might be too close together to clear the lights on my Toyota. The wd21 carrier was my original plan, it matches the era of the truck better and is a little bigger for mounting crap to. I know mine was stout as hell too.
Edited by trader
Thanks anyway guys. I snuck up to one parked on my street and got the measurements I needed. It may just work. I may be putting a WD21 carrier on a 1st gen 4Runner body.
I'm thinking with the carrier, new hinge pins/bushings, zerks and metal I should be able to do this for well under $100- much less than it would cost me to make a carrier arm for my bumper that I might not keep anyway. If I can make it work, I'll post up. Now to find one in decent condition for a good price...
josh
