Walker pre bent exhaust
TugboatTony
I've just finished doing the exhaust on my '95 SE. I drilled, ez-outted and replaced the typical broken manifold studs and if that wasnt a pain in the a** enough. I replaced the entire exhaust with 'Walker' pre bent pipe only to find out the O2 sensor bung from the factory is the wrong size. I had to grind it off and weld in the proper size. (the parts store had the bung alone). Just wanted to throw this out there if you decide to go this route as well.
Anthony
