adamzan Posted September 21, 2011 Share Posted September 21, 2011 (edited) So I've been battling this vibration issue for what seems like forever, and it is getting worse. I have ruled out the front end as it is perfectly tight and aligned. The universal joints are new and all the weights are on the drive shaft. If you set the cruise at any given speed, the vibe will come and go. I just got my new tires on yesterday and it was the same with the old tires, so I know it is not a tires problem. I even swapped the old tires onto my friends silverado to see and it drove smooth right till 140km/h. But then I noticed, there is play when you grab the drive shaft and try to move it, but at the transfer case. I would say there is about 2-3 mm of play there, you can definitely see it move. So I have a few questions: 1. Could this be causing the wobble at 65km/h~, and the vibe I have at 90-130kmh (it probably does it at higher speeds but the frequency is so high that it is not noticeable). 2. Can this be fixed on the truck? 3. Is it something I could do or do I need special tools (send it into a mechanic)? Edited September 21, 2011 by adamzan Link to comment Share on other sites More sharing options...
SteeevO Posted September 21, 2011 Share Posted September 21, 2011 when you say there is play in the driveshaft do you mean moving it up and down 2 - 3 mm? or by twisting it? Link to comment Share on other sites More sharing options...
Tungsten Posted September 21, 2011 Share Posted September 21, 2011 (edited) He told me it moved up and down. Edited September 21, 2011 by Tungsten Link to comment Share on other sites More sharing options...
adamzan Posted September 21, 2011 Author Share Posted September 21, 2011 Up and down. I took it to someones place today that knows a lot o about this kinda thing and he said that it is normal for it to have a bit of movement like it does. I'm still not sure, its not like the little disc thing on the drive shaft touches the cover, but it moves. Link to comment Share on other sites More sharing options...
