crank case oil leak?
jeremyelvis
Do you mean the oil pan? Unfortunately it's a pain, because (if you have 4wd) you have to remove the front diff to take it off. Probably a full day of work for a do-it-yourselfer (unless you have a lift). Dunno what a shop charges for that... There isn't much that is particularly complicated about it though... grunt work.
