My transmission cooler.
onefast87
The install was straight forward.All it took was the help of a good friend. I like the way it came out.
I used a Hayden cooler.The cost was about 90$ total, took about 2-3 hours.I would still like to get a Temp gauge.
The next project will be a remote turbo.
http://www.oreillyauto.com/site/c/detail/HAD1/404.oap?ck=Search_N0940_-1_-1&pt=N0940&ppt=C0377
I used a Flex-a-Lite 4118 (18,000LB) on my truck, the dimensions are almost identical. I put mine in the same place, but ran the lines underneath the radiator. shortest route to the transmission lines.
Under heavy load, it won't go above 150*. I'll have to haul something sometime and get a temp reading....
