Fuel cutoff
sewebster
I was discussing the fact that modern engines completely cut off the fuel supply when you are just coasting down a hill with a friend on the weekend. We were wondering what sensor parameters the ECU needs to determine it should do this. I guess it could look at a combination of throttle position or MAF and engine RPM to see if the RPM is higher than it would expect and therefore figure out you are going down a hill?
Also, does anyone know if pathies (MPFI vg30) cut off only at zero throttle, or if they can cut off if you are very slightly on the pedal as well (you might want to coast downhill a bit faster, but not as fast as the higher gear)?
