front oil leak
Could be your forward main seal or your forward cam seals. or all 3. you'll need to remove your timing belt, and timing gears and inner timing covers to get to all of them. See Timing belt in the how-to section for guidance.
If its really bad I'd fix it soon, the Oil may be softening up your timing belt.
sounds expensive,might just dump it before I sink alot of money into it
If you're gonna dump it, you might want to try it yourself. The seals themselves are only a few bucks. It's all labour. I guess you should do your t-belt too, and that's maybe $50.
