blackspawn Posted May 9, 2011 Share Posted May 9, 2011 My rigs is starting to pull bad to one side so I'm going replace alot of parts on the front; but I dont know which brand as far as ball joints and tie rod ends to get; I'm also thinking of doing the wheel bearings too. So what is everyone using!? Link to comment Share on other sites More sharing options...
Dowser Posted May 10, 2011 Share Posted May 10, 2011 Are you sure its those components that need replacement First? Have you checked for play or anything? Have you tried just getting an alignment first? Usually if its pulling to one side thats an alignment issue and not necessarily front end components. You'd be getting things like wandering and vibrations for worn out front end parts. You can check to see if these components are worn out fairly easily. Link to comment Share on other sites More sharing options...
JamesRich Posted May 10, 2011 Share Posted May 10, 2011 I just hit Oreilly and got their lifetime warranty parts. James Link to comment Share on other sites More sharing options...
cdnleaf Posted May 10, 2011 Share Posted May 10, 2011 (edited) When I swapped out the UCAs I went with NAPA upper ball joints (similiar to Moog/lifetime warranty.) Lowers are still solid / no play. I will probably go with NAPA again for new inner/outer tie rods and adjustors, when needed. Edited May 10, 2011 by cdnleaf 1 Link to comment Share on other sites More sharing options...
blackspawn Posted May 10, 2011 Author Share Posted May 10, 2011 Are you sure its those components that need replacement First? Have you checked for play or anything? Have you tried just getting an alignment first? Usually if its pulling to one side thats an alignment issue and not necessarily front end components. You'd be getting things like wandering and vibrations for worn out front end parts. You can check to see if these components are worn out fairly easily. I had it checked awhile back and they said that they could give it an alignment but it needs ball joints; they took me in and did the movement of the wheel test and it does need ball joints. I just thought that since I'm doing those I might as well do the whole front end of this 21 year old rig. Link to comment Share on other sites More sharing options...
thehuntersam Posted May 11, 2011 Share Posted May 11, 2011 Whatever you do get, make sure they have lifetime warranties. It will save you in the long run. Link to comment Share on other sites More sharing options...
5523Pathfinder Posted May 11, 2011 Share Posted May 11, 2011 I just put all Moog components on my rig earlier this year(along with a Grassroots centerlink). They are bigger than stock and have grease fittings! They are great, and the price was right! Link to comment Share on other sites More sharing options...
blackspawn Posted May 12, 2011 Author Share Posted May 12, 2011 I just put all Moog components on my rig earlier this year(along with a Grassroots centerlink). They are bigger than stock and have grease fittings! They are great, and the price was right! This sounds like a WINNER!! Link to comment Share on other sites More sharing options...
5523Pathfinder Posted May 12, 2011 Share Posted May 12, 2011 Here is a crappy pic of what they look like. I was able to immediatly nail the alignment when I was done! Link to comment Share on other sites More sharing options...
blackspawn Posted May 12, 2011 Author Share Posted May 12, 2011 nice.. Link to comment Share on other sites More sharing options...
