cv axle diagram/ pic
Changing both Cv axles. And putin warn manual hubs on. Got the rotors and hub assembly off, but not sure on were to go now... do I have to unbolt the strut tower? Or take anything else off? A diagram would be much appreciated!
Friend, you took way too much off! You need only undo the 6 bolts on the axle side, and undo the hub part. Push and turn and wiggle it down through the control arm. Wala.
Jose
I'm changing the rotors to so I had to any ways... and that's what I figured but I didn't know... also putting manual hubs on... but thanks for the clarification guys!
