TooQForYou Posted April 13, 2011 Share Posted April 13, 2011 I have two Hella 550s (55w) hooked up to my R50. According to calculations, 110w on a 12 volt system would be 9.16 amps. But I just blew a 20amp fuse. What's going on here? Link to comment Share on other sites More sharing options...
Precise1 Posted April 13, 2011 Share Posted April 13, 2011 Is it when you turn it on or when it has been on for a while. If it is at first, maybe there is current surge? If it is when it was on for a while, I'd suspect you are grounding out somewhere. Trace the wires to make sure they are dry, tight and not rubbing through anywhere. B Link to comment Share on other sites More sharing options...
TooQForYou Posted April 13, 2011 Author Share Posted April 13, 2011 Well I had used them a few times without problem. Then the other day they just wouldn't come on, so I guess it happened when I flipped the switch. Link to comment Share on other sites More sharing options...
Precise1 Posted April 13, 2011 Share Posted April 13, 2011 Replace fuse (maybe it was poorly made) and try again to see if/when it blows. Oh, hey, is this through the fuse box or through a relay with a dedicated inline fuse?? Often fuse box circuts run more than 1 item so you may be overloading it when you turn something on... B Link to comment Share on other sites More sharing options...
TooQForYou Posted April 13, 2011 Author Share Posted April 13, 2011 I replaced the fuse and flipped the lights on and all works. This is through a relay with a dedicated inline fuse. Link to comment Share on other sites More sharing options...
TooQForYou Posted April 14, 2011 Author Share Posted April 14, 2011 (edited) Just blew another 20amp fuse. WTF?! EDIT: I think I'm shorting out somewhere between the fuse and the relay. I'll take a look tomorrow and report back. Edited April 14, 2011 by TooQForYou Link to comment Share on other sites More sharing options...
