87SEdan Posted February 26, 2011 Share Posted February 26, 2011 (edited) So I am having the common my speedo doesn't work issues. I've searched and found help, but conflicting solutions. Here are my issue 1-of all the gauges work except for the speedo 2-I replaced the speedo cable and the speedo goes straight to max and stays there 3-I read that there is a relay that can be replaced in the back of the cluster, does that apply here? Wouldn't that mean all gauges would be dead? 4-my shop is trying to get me to buy a new cluster, I'm trying to avoid this That's it guys, any help is greatly appreciated P.S.-what is the difference between off-road 87 models and non off road? The reason I ask is my gauge cluster is different than some I've seen on here from the same year. It looks like mine has 2 gauges for gas, one above the other. I'm confused lol Edited February 26, 2011 by 87SEdan Link to comment Share on other sites More sharing options...
nunya Posted February 26, 2011 Share Posted February 26, 2011 Dual fuel gauges? Make the cluster metric and I want it! Our speedometers are cable driven, 0 electronics involved other then the light. The gauges CAN be replaced individually if it is a gauge issue, which I am gonna try to understand better right now. The needle stays pegged 24/7, truck moving-stopped-when not running? Any time the needle settles? does you odometer still count the miles? Any needle flickering at all rolling? Rolling in reverse make iffy to drop at all? Link to comment Share on other sites More sharing options...
