benny Posted February 6, 2011 Share Posted February 6, 2011 Trying to install XenonDepot's 4300k Bi-Xenon 9007 headlights in my (wife's) 2007 Nissan Pathfinder, and I'm having trouble. I have one bi-xenon headlight installed, driver side. The high beam works fine, no problems. The low beam does not work, and I keep popping fuses. I'm stepped up from the factory 15A fuse to a 20A and a 25A, same thing. I don't really want to go higher than that, and don't think I should have to. I've checked all the wiring/connections. It looks good. The high beam fuse is 10A, if that tells you anything. I think my ground is pretty good, if it was bad the high beam wouldn't work I believe. I also plugged in the other ballast temporarily (to see if its the first ballast) - same thing though. I really need to get my wife's car operational today (and that might mean reinstalling OEM lights). Any advice/feedback would be helpful. Link to comment Share on other sites More sharing options...
morpheus Posted February 6, 2011 Share Posted February 6, 2011 try swapping the bulb HID bulbs draw approx 5 amps each, no way you need that big a fuse. make sure you didnt pinch any wiring either. Link to comment Share on other sites More sharing options...
devonianwalk Posted February 7, 2011 Share Posted February 7, 2011 I certainly would NOT go with higher amperage fuses. The fuse is there to protect the wire from getting to hot and catching on fire. If you have to go with a larger fuse you will need to go with a larger gauge wire. Mrpheus has a great idea to re-check your wiring to see if the wires jacket has not been compromised. Link to comment Share on other sites More sharing options...
laxman0324 Posted February 14, 2011 Share Posted February 14, 2011 Return the HID kit because our lenses are not compatible with the light output from those bulbs and you will be blinding oncoming drivers to get good light for yourself. Link to comment Share on other sites More sharing options...
