Replacement Antenna 94 Pathfinder
ahardb0dy
94 pathfinder originally had the power antenna, I know most Nissan pickups and PF's have the antenna on the top of the fender, (more forward on older ones, closer to windshield on the newer ones), my 94 had the power antenna but previous owner must have kept it (along with all the speakers and radio!!), so wanted to know if anyone has found a universal replacement antenna that will work in place of the OEM power antenna? I don't need or really want a power antenna and it would be easy to cut the rectangle hole to mount a non powered antenna in the top of the fender or replace the whole fender, but trying to keep costs down.
P.S. - I did not search because the search sucks, (sorry)
Thanks
I got ya, you mounted the antenna base below the fender and ran the aerial thru the hole, I think I may just pick up a fender with the normal antenna hole from the junkyard, or see if I can find a universal antenna that will mount in the hole. Thanks appreciate the pics.
