Guest vrojkov Posted October 29, 2004 Share Posted October 29, 2004 I need a help with AC wiring diagram for my Pathfinder LE, 1998. It has so called semi-automatic climate control. I have a problem with my AC it blows really hot air at any temperature control position except min position. In min position it produces real cold and my AC switch and an AC works. Now I need a help how to trace and fix the problem. Should I start with checking blower motor or blower door opener? Please do not advise me to check FUSES! Did it already 3 times . I would prefer to start with wiring diagram. If somebody will help me find it. Thanks all. Link to comment Share on other sites More sharing options...
Pathfinder_Rookie Posted November 28, 2004 Share Posted November 28, 2004 Hey still looking for the ac diagram? I have/had the same problem i had that problem in the summer but when the temp outside started to cool down it worked much better, center setting temp is the perfect setting if its like -20C and you rig is warm and windows are up. Let me know. Link to comment Share on other sites More sharing options...
Pathfinder_Rookie Posted November 28, 2004 Share Posted November 28, 2004 You know come to think of it there is a plastic shield/screen under the wipers, which covers the top of the firewall. On top of that screen there should be a piece of weather striping that seals to the hood make sure that its in good condition. Cause your blower may be sucking warm air from your engine into the cab. Do u also have really bad fogging problems when it rains? Cause I do and your post triggered an idea that my stop fogging in my rig, it may also help with that warm air problem of yours. Ill hopefully post my results soon. Thanks Pathfinder_Rookie Link to comment Share on other sites More sharing options...
